SailNet Community - View Single Post - How important is it to change zincs in fresh water?
post #3 of Old 06-18-2007
sailingdog
Labatt-
Galvanic corrosion is still a problem in freshwater. However, zincs made of zinc are not generally reactive enough to provide your boat sufficient protection in fresh water. Fresh water boats should have either aluminum (brackish water usually) or magnesium (pure fresh water) zincs. If you've got zinc-alloy zincs, they can often not be affected while the aluminum parts of your boat get attacked.
You should also keep a notebook on the boat, preferably in the maintenance log, that lists the important consumables and what their size/part numbers are, so you don't have to haul the boat to figure it out. Oil filters, fuel filters, impellers, zincs, clevis pins, shear pins, and other things like that should be on the list IMHO. Also, might want to list various fuses and what amperage is used for what circuits.
sailingdog is offline
