SailNet Community - View Single Post - Low Maintenance Brightwork: Varnish or Linear Polyurethane over Epoxy?
post #5 of Old 06-19-2007
sailingfool
ASA and PSIA Instructor
You should definatitely go with the Cetol. If you use epoxy/varnish, some day when you or a subsequent owner has to remove it all, you will wish you hand't used it. The magic of Cetal is that it is not hard to remove, when you need to start over.
sailingfool is offline
