Just remember that the amp-hour level of a battery bank is also dependent on the size of the draw. If the draw is fairly low, the effective amp-hour rating of the battery bank will be higher than if the load on the bank is high. The higher the load, the lower the effective amp-hour rating of a battery bank will be.
The GPS is a fairly light load, and will give you a fairly long run time. A 120 Watt 12 VDC searchlight will kill the battery far more quickly, probably bringing you down to the 50% level in 8 hours, rather than the 9.5 hours you would expect.
