It isn't a fast job... it isn't all that complicated either... Tomaz's idea of using two lines works fairly well, as that is what I did... rolling hitch to the drogue and haul it in until the line is too short... then do it with a second line and alternate. The line I used is a bit longer, and I actually run it forward to a block at the base of the mast and then back to the drogue... that way I can haul in a longer section of drogue between rolling hitches.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
