SailNet Community - View Single Post - Need some electrical/shore power advice, please
post #2 of Old 06-20-2007
sailingdog
Hooking a 30 Amp Shore Power system on a boat to a 15 or 20 Amp system is not a problem generally, as you are rated for that much current... but the adapter cords are a shock hazard and you really need to find a marina that uses proper shore power outlets.
As for the inverter... if it is properly wired, she should be able to use the hairdryer when on shore power with no problem, regardles of whether you are at a 15, 20 or 30 Amp shore power connection.
While I can't speak for using it on the batteries alone, I wouldn't use it based on the size of your house bank, which is only about 200 amp hours, and the 1500 W hair dryer will be drawing the equivalent of 125 Amps or so at the batteries when it is on... not a good idea... don't think your DC-side wiring is sized for it.
sailingdog is offline
