SailNet Community - View Single Post - Cables rattling in mast?
post #5 of Old 05-30-2002
walt123
If you have internal halyards you have to run a wiring tube inside the mast. If external halyards remove the wire leaving a messenger line attach pieces of foam slightly larger thne the mast every few feet to the wiring as you rethread it up the mast.This should stop the clanking and make your neighbors very happy.
walt123 is offline
