SailNet Community - View Single Post - Water system
Thread: Water system
post #5 of Old 05-31-2002
SHIMSHON
Water system
Does the fresh water pump cycle when you turn it on? Is there an accumulator tank in the system? Have you checked the in line filters to make sure they are clean of debris? Does your pressure switch on the pump work? Have you checked the in line valves-are they open? Just a few areas to check, assuming first of all that you have water in the tanks!
SHIMSHON is offline
