SailNet Community - View Single Post - Buy Used Mainsail?
post #3 of Old 06-25-2007
Sailormann
Here .. Pull this
If it's a dacron cruising sail, you should be fine. If it's a laminate sail of any kind - I would suggest you not get it as they are usually cut and shaped/moulded for a particular hull form, and they also deteriorate pretty quickly.
Not sure about the boom following it up the stick, as I would expect (hope ??) your gooseneck is pretty securely attached to the mast.
Sailormann is offline
