SailNet Community - View Single Post - Catalina 34 Starting Battery Problem
Old 06-04-2002
lgsailor52 lgsailor52 is offline
lgsailor52 is on a distinguished road
Look for corrosion at the terminal connections and your ground. Also look at your power (battery) switch. There may be internal corrosion, or corrosion at the connections. A loose connection may also be the cause.
