Old 06-28-2007
SEMIJim's Avatar
SEMIJim SEMIJim is offline
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Originally Posted by 7tiger7
On a Catalina 27, which of these options are better? Pro's, cons?
Tiller or wheel?
On a 27' boat: Tiller, without question. The cockpit on a 27' is going to be far too small for a wheel. Plus you won't get the feel of the boat nearly as well from a wheel as you will a tiller.
IMHO: Anything under 32' feet is best with a tiller. Around 32' - 34': Could go either way. For cruising, a wheel would probably be less tiring. For pure sailing enjoyment: A tiller might be more fun. 36' and above, you probably want a wheel. (See caveat below.)
Inboard or outboard?
Coffee or tea?
Seriously: "It depends." A long-shaft outboard is perfectly capable of driving a Cat 27 to-and-from a days sailing. It has the advantage of easy maintenance and easy replacement. You can raise it up, getting the prop entirely out of the water, for slightly better speed under sail. OTOH: It might not fare as well in following seas, it won't have near the battery-charging capability, and it'll be a bit noisier.
For racing: Outboard. For cruising: I prefer inboard.
Thanks very much!
You're welcome.
Now, the caveats: I don't currently own a boat. Nor have I sailed in the last 25 years, other than crewing on one race (on a Cat 27, in fact, with tiller and outboard), a couple weeks ago. However I have been looking at boats for a month and reading voraciously. The point being: My tiller vs. wheel opinions, in particular, represent numbers I more-or-less pulled out of my... er... family forum... right... pulled out of the air .
Jim
