Old 06-28-2007
hellosailor's Avatar
hellosailor hellosailor is offline
hellosailor will become famous soon enough
Cam-
Dunno about gels at all, but the conventional numbers for wet cells are 1/5thC and for AGMs 1/4C rate. How do you safely charge them faster than that? Gotta be a less-than-conventional charging protocol or tighter controls required, including thermal sensor?
Double belts are passe these days, v-belts in general are actually getting damned hard to find in stock. Ribbed belts will handle all the power--with just one belt and no constant need to even out the tension between two V's.
