Basically, the inboard is going to be a better choice as a powerplant, but the outboard leaves you with more room and storage space in the boat. If you're a sailing purist, and will not motor much, and plan on taking longer voyages in your boat, it might make more sense to get an outboard-equipped model.
The tiller is definitely the way to go—much better than a wheel—simpler, takes up less space when at anchor, and more reliable.
