Thread: bilge pump DQ
Old 06-04-2002
scottcallahan scottcallahan is offline
scottcallahan is on a distinguished road
bilge pump DQ
i''ve never seen a rule product that doesn''t leave 1/2 inch of water. the best you can get is 1/4 inch with a different setup. the setup goes as sutch you get a diaphram pump and mount it close to the bilge but not in it. run a hose to a strum box otherwise known as a bilge strainer.
the diaphram is designed to let the water only go one way. and stops water from flowing back. and the strainer allow''s you to drain to a lower level.
but all of this is not worth doing. the thing
i would do, is sponge out the bilge and get it dry so you can look for leaks and fix them . and if you fix them you wont have a wet bilge.
hi VIEXILE i''ve seen you on alot of these, are you a marine technitian or do you just have alot of time around boats?
-scott-
