SailNet Community - View Single Post - $3000/mo cruising budget
post #322 of Old 03-11-2014
killarney_sailor
Bristol 45.5 - AiniA
Re: $3000/mo cruising budget
Originally Posted by findrichard View Post
Wow, refit costs are much less than I would have thought. That is encouraging. I have always thought sails and running rigging were only good for about 5 years of constant use and standing rigging was ready for replacement every 10 years of constant use.
You don't sail around the world and then refit. You take advantage of opportunities when you see them. For example, we replaced our wire/rope main halyards in South Africa because the local rope manufacturer (Southern Ropes) had a terrific price on Dyneema.
I think from your questions you are looking for really clear, exact answers for things like budgeting. It does not work that way. We are all different and and our boats are all different. If you have an older diesel (ours is 1990 and 4000 hours) it can be working just fine one day and need a rebuild the next - or it might be fine for five more years - how do you build things like that into the budget. We travelled fairly cheaply (probably $1500 a month) but we have a good nest-egg available if we have a costly repair or want to head off for a couple of weeks in New Zealand or South Africa. Everyone's mileage will vary.
Finishing our major refit. Our trip to Newfoundland is off because it is too late. Hoping to go to the North Channel instead.
killarney_sailor is offline
