SailNet Community - View Single Post - How does this thing work?
post #5 of Old 07-01-2007
sailingdog
Dan-
I have basically that same fixture on my boat, and it is self-priming. It has to be, since the water tanks are generally mounted far lower than it. Most of the manual pump faucet fixtures on boats use a self-priming pump of some sort.
mwrohde-
If there is water in the cooler sump, then the valves are not in the correct positions. You may want to try changing the positions of the valves, after you confirm that the faucet does indeed work. If the faucet isn't plumbed into the boat's fresh water system, disconnect the hose at the bottom and put a temporary hose on it into a dish or bucket of water... and try pumping the handle. If water comes out, then the faucet pump mechanism isn't the problem.
sailingdog is offline
