SailNet Community - View Single Post - Nav Station Design
post #4 of Old 07-02-2007 Thread Starter
Mithril
Thanks for the reply John. For the 110, I have purchased a Xantrex Freedom Marine 25 Inverter/Charger. It might be a bit overkill but it should do the job.
Because my daily refrigeration needs are only 13.8 amps, worst case, I was able to reduce my house bank design from 600 Amp Hours to 500 Amp Hours. I also have a Xantrex Link 2000R which I plan to install above the electric panel which will actually be aft of the Nav Station.
As far as the bilge pump I thought to only have the switch on the electric panel.
I recognize several items, but not everything. Looking at your picture, on the left panel you have a breaker panel and couple of 12V outlets I think. Is that circular instrument for your tanks or what is it? Also what is below that and above the 12V outlets?
The right panel has your marine FM radio? or does that have XM capability? Another breaker panel in the lower left, but what is the square item in the upper right and the dials below?
I didn't notice your VHF or how you receive weather information?
Thanks again,
- Craig
Mithril is offline
