SailNet Community - View Single Post - Hull Speed
Thread: Hull Speed
post #7 of Old 07-03-2007
sailingdog
Originally Posted by timangiel
Can a boat sail faster than hull speed and how good is the formula for calculation? If hull speed is calculated by the sqaure root of the lenght at the water line times 1.34 it does not seem right to me. My boat is 26 ft LOA but is 23 ft at the water line. The sqaure root of 23 is approximately 4.8 and if I multiply this by 1.34 I get a hull speed of 6.4. According to my knot meter I sail quicker than that on a regular basis. Is my formula wrong, is my math wrong, or is my knot meter wrong?
A knot meter isn't the thing to use to check boat speed. It may not be calibrated accurately, it may be affected by tidal currents... Have you checked the speed via a GPS.
Also, what kind of boat do you have. There are many smaller boats that can plane or surf. A Foiler Moth can sail well above its hull speed, since it lifts up on a set of hydrofoils. The basic SQRT (LWL) * 1.34 rule really only applies to displacement hulls. It fails on multihulls, small dinghies, foil-equipped boats, and a few others.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
