SailNet Community - View Single Post - Gusts While Sailing
post #8 of Old 07-03-2007
danjarch
Siren 17
danjarch's Avatar
You should reef any time you start to suspect that things could get out of control. If you get a gust or two that are little pushy your probably ok. If your getting pushed pretty far over, If you find your getting headed up, then having to fall back into the after ever gust. you should have already had a reef. It will make you a faster and safer sailor. A good pratice would be to reef your sail any time there is some good wind blowing. Then when you get out there, if your not moving worth a darn, you can shake the reef. This will give you a lot of quick pratice. Later when you need to reef on the quick you'll be ready.
!! WARNING !! The above information is to be used by intelligent people only. If you are Stupid, could be considered a moron, or otherwise. You are instructed to disregard this information and seek the help of a licensed and bonded professional.
danjarch is offline
