SailNet Community - View Single Post - Most Useful Sailing Tool
post #25 of Old 03-15-2014
manatee
manatee's Avatar
Re: Most Useful Sailing Tool
Originally Posted by Minnesail View Post
The Wave is easily opened and closed with one hand.
It also has a ruler along the handle, which I find comes in quite handy.
The Phillips head screwdriver uses a replaceable/reversible bit which I understand could come in handy. If you strip the bit it's easier to replace than the whole unit, but... The one and only time I've been up a mast I was using it to replace the steaming light and naturally before I even had the first screw out the bit came loose and went bouncing all the way down to the deck...
Magnetize the bits with the strongest rare-earth magnet you can find, or put one of the tiny magnets from a magnetic socket in the bottom of your Leatherman socket. Or carry spares...
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
