SailNet Community - View Single Post - Anchor's and engine block away?
post #11 of Old 07-09-2007
sailingdog
The problem with concrete blocks is that they are far less dense than an steel mushroom anchor or cast iron engine block—so the effective weight they represent is far less, given the same mass. Also, a mushroom anchor, will tend to be fairly effective, more so than its actual mass would indicated, as it becomes buried in the bottom over time. Concrete blocks may not bury themselves as effectively, nor may an engine block, which presents a much larger surface area to the bottom than the much more compact mushroom anchor does.
sailingdog is offline
