SailNet Community - View Single Post - how to pull a motor?
post #11 of Old 03-19-2014
erps
the pointy end is the bow
erps's Avatar
Re: how to pull a motor?
560# straight up with a comealong? man that sounds scary!
I suppose, until you've seen it done. I was a mechanic in the army and out in the field we swapped out a lot of transmissions in big trucks with a come along and a big steel pry bar laying between two supports in the cab. Even the cheap ass come alongs I use to keep in my jeep when I was a kid were rated at 2000 lbs. A small chain fall might be better though depending on the vertical clearance between your motor and the bottom of your lifting beam.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
