SailNet Community - View Single Post - how to pull a motor?
post #12 of Old 03-19-2014
Faster
Re: how to pull a motor?
Depending on your access, you can also remove a lot of weight before the lift.. manifolds, Heat Exchangers, alternators, brackets will remove weight and reduce bulk for easing the engine out of the space.. If a rebuild is in the works all that has to come off anyhow.
Faster is online now
