You can probably scarf in a new piece of the extrusion that holds the rub rail in place, by lifting the teak toe rail a bit. The rub rail you can probably buy from a couple of different manufacturers.
Taco Marine makes replacement rub rail in a variety of shapes.
I would highly recommend you check the deck and hull very carefully, as there may be some damage to the hull deck join.. .and that means it will leak.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
