SailNet Community - View Single Post - Varnish on both sides?
post #3 of Old 07-09-2007
sailingdog
I would slap a layer on the bottom to seal out the moisture...which is what the varnishing is all about to begin with. It shouldn't interfere with the sealant, as long as the varnish is well adhered and completely dry before you apply the sealant. It will also, probably, help keep the varnish on the other sides in better shape, since moisture getting underneath the varnish is a big source of varnish failures IIRC.
sailingdog is offline
