Old 07-09-2007
sailingdog sailingdog is offline
sailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the roughsailingdog is a jewel in the rough
Given that the hull is that thick and that the inner hull surface is relatively flat, I would have to agree that there really is no need for a backing plate.
The only question I have is have you check to see if the hull there is solid laminate. Some boats have cored hulls, if yours does not...then don't worry about it... if it does, then you should make sure the area is solid glass rather than cored laminate.
If you're new to the Sailnet Forums... please read this POST.
Sponsored Ad
