SailNet Community - View Single Post - Failed manual bilge pump
post #2 of Old 03-20-2014
chuckbauer
Re: Failed manual bilge pump
Andrew, had the same pump on my IP 26 MK II which also failed. I could find no direct replacement so went with something like a Whale Compac 50.
No at the boat until this weekend so not sure of exact model. It fit ok except the bolt holes were different so had to do a little filling/patching.
It is mounted on the starboard side of the cockpit maybe a foot forward of the locker.
Defender has them. If I run across the paper work I'll post the exact mode.
Good luck.
Chuck Bauer
Etude, IP 26 MK II Hull 78
chuckbauer is offline
