Thread: Overhead liner
Old 07-10-2007
sailingdog sailingdog is offline
It depends on what materials you want to use for the overhead liner and how accessible you want the underside of the deck to be. The most elaborate way to do it is to mount furring strips along the overhead surface, where the strips are either screwed or glassed in. Then you would mount the finished interior surface to the strips. This allows easy access to the underside of the deck, and gives you a very good way to mount the panels for the overhead.
Less elaborate ways would be just gluing the material to the surface, but this causes problems if you have a leak and need to get access to the bolts for a deck fitting.
