SailNet Community - View Single Post - Maiden Voyage Newbie Trainwreck
post #26 of Old 03-23-2014
eherlihy
Learning the HARD way...
eherlihy's Avatar
Re: Maiden Voyage Newbie Trainwreck
First off - Congratulations on completing your first sail, making it back to your slip, WITH NO DAMAGE!!! Not many here could make that claim...
Second - with all due respect to the prior posters, I gotta disagree with the value of a handheld VHF with DSC, or a RAM mike. Personally, I think that your dollars are better spent on a fixed VHF with DSC, and a handheld floating VHF without DSC for the cockpit. I suspect that you may also spend some bucks connecting the fixed VHF to a GPS (so that the DSC works), ensuring that the fixed VHF works well (this may require a new antenna cable, connectors, and new antenna). I like carrying a handheld VHF (sans DSC) that floats, for redundancy and near shore communications.
I outline the procedure to follow in case of emergency to all my crew, and it involves pushing the red button on the fixed VHF which is always in the same place, and then searching for the handheld (which is usually in the cockpit, or recharging at the nav station, but may also be used if someone is out in the dinghy). I use the fixed unit for emergency use, and, frankly, as a backup to the handheld.
There is no right or wrong answer to this, and you need to work out the best value for your circumstance for yourself.
eherlihy is online now
