I am aware of that... and his boat is at his dock... if you read the post I was referring to about detecting DC leaks, it clearly is for tracing leaks caused by a boat's own DC electrical system.
Originally Posted by Fstbttms
Rapid anode depletion is far more likely to be caused by an electrical problem aboard the boat in question than it is to be caused by a "hot" dock or marina. While it can't hurt to check for stray current in the water, TXS-ALAMO should consider going through his boat's electrical system as well, IMHO.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts..
