SailNet Community - View Single Post - Aging Rigging
Thread: Aging Rigging
post #4 of Old 07-12-2007
sailingdog
Actually, come to think of it...there might be a better solution if the problem is that the rigging is too stretched out to tighten further. Cut a bit off the bottom of the shrouds and stays, and then put a StaLok or HiMod swageless fitting on there... That would remove some of the length, and still allow you to adjust the rigging properly. Also, you could re-use the fittings for when you replace the rigging.
sailingdog is offline
