SailNet Community - View Single Post - Lifeline netting...
post #4 of Old 07-15-2007 Thread Starter
scurvy
scurvy's Avatar
Send a message via AIM to scurvy
Originally Posted by Jotun
You can generally lace the lifeline through the top of the netting to hang it. I am still searching for a good way to attach the bottom.
Hi Jotun!
This is what I had hoped that I could do, but the swags and everything else would need to be removed, etc....
I will probably run half hitches around it for now, send another line (5mm nylon/poly) down around the base of the stanchions with clove hitches and tighten it as I go, then half hitch the netting to the new line that is run between the stanchions. My Albin Vega does not have any attachment points along the toe rail.
I have yet to have one of those moments where the light goes on and you say to yourself "Ah-haaaaa". This will just have to do until I figure out or see a better way to do this.
Chris
scurvy is offline
