SailNet Community - View Single Post - Need Rigging Advice
post #4 of Old 03-30-2014
manatee
manatee's Avatar
Re: Need Rigging Advice
Originally Posted by Sailing Pit Bull View Post
Hey guys,
I have a 1974 O'Day Widgeon and when I got her, there was very little of the original rigging intact or even present. So I have a few questions that I was unable to dig up using the search function.
First, is there a particular type of rope I should be using? the rigging that was present was all 1/4" three strand laid. I had read previously in several instances that I shouldn't be using anything less than 3/8", and the tackle in most instances looks better with 3/8" rope being used. Is nylon rope acceptable or do you have any recommendations? I do prefer three strand laid as I'm rather familiar with splicing already and would prefer not to relearn. As they say, if it ain't broke, don't fix it.
Secondly, from what I have seen in various diagrams, I have several options for the mainsheet. There are two that appear to fit the bill, so for this discussion the other options will be discarded.
The first is using the mainsheet as the traveler. It would go from the swivel/clam cleat to the middle of the boom, then to the pulley on the back of the boom, to an eye on the starboard side of the stern, to the eye on the port side of the stern, and then be made fast to an eye on the very end of the boom.
The second option uses a rope bridle traveler secured to the two eyes on the stern of the boat either with a bowline or a stopper knot. The mainsheet would then pass from the swivel/clam cleat as previously stated down the length of the boom. After passing through the pulley on the end of the boom it would drop down to a pulley which would ride on the traveler and return back to the boom to be made fast on the eye on the very end of the boom.
Are there any pros and cons to either of these arrangements? Any advice or opinions are more than welcome. Thanks guys!!!
Seth,
Welcome.
Found this thread:
http://forums.oday.sailboatowners.com/showthread.php?p=761644
To search a particular forum/website for info: in your search engine window, format a search request like this--
"o'day widgeon rigging" site:http://www.sailnet.com/forums/
1) use the quotes around multi-word search terms to avoid irrelevant results based on single words in your search.
2) *important* no {space} between "site:" and site address.
Fair winds, have fun!
"The skipper should be the calmest person on board. It is good for the morale of those around you. However, if everyone around you is frightened then be aware of the possibility that they know something you donít."
~~Dylan Winter,
manatee is offline
