SailNet Community - View Single Post - Sealing hull-deck joint
post #7 of Old 03-31-2014
jimgo
Asleep at the wheel
jimgo's Avatar
Re: Sealing hull-deck joint
Christian, I hope not. I have some serious leaks that I need to tackle in the next few weeks because the water starting to damage the wood inside. I was trying to find the source and noticed that it looked like the fiberglass was weeping from the inside. My guess is that the water is traveling in and down along the glass to a spot where it can come out. Unfortunately, there are a LOT of possible intrusion areas near where I saw the water. I'm going to try rebidding the windows and jib car tracks first, then the stanchions, and then finally, if that doesn't solve it, I'll look at the hull/deck joint.
- Jim
Home: Western Philly 'burbs
1980 Allmand 31
1975 Albacore 15
jimgo is offline
