SailNet Community - View Single Post - safe cooking
Thread: safe cooking
post #143 of Old 03-31-2014
guitarguy56
guitarguy56's Avatar
Re: safe cooking
Originally Posted by GeorgeB View Post
Out of mild curiosity, what is the amp draw on an induction stove-top? I am assuming that this set up would mean an electric oven too? I like my propane (but then again, I cook with gas at home). Never once have I had a flare-up like when I had an alcohol stove and singed the cabin curtains. We used to have a paraffin trawler lantern in the cabin but got tired of the oily film and soot on the overhead if it wasn’t adjusted properly. But, I can see where propane or electric might not be practical for Jack’s boat and budget. Get what you can afford and take proper precautions and enjoy your boat.
George... it sounds like you're a little curious and you should be. My induction stove is super efficient... why?... one simple reason... it draws only the amount of electricity it needs in an instant to heat water or whatever... uses only the power it needs and nothing else... unlike an electric stove with resistance heating it must warm up... ever plug in a soldering iron waiting for it to heat up or an iron, etc.... that is the resistance element heating up and must be at full power to get to proper heat... that is wasting a lot of wattage right there... not so with the induction stove... it's electronic and turns on and off as needed to maintain the temperature.... your electric stove is on all the time at at set control timing.
That really is the difference... it uses very little wattage!
And to Tempest it ran on a 2000 watt pure sine wave inverter but I wanted power for other items so exchanged it with a 3000 watt pure sine wave inverter... works beautifully if may say so. My added plus is I'm not buying $12.00 a gallon of alcohol or the danger of an alcohol spill or fire!
Jack would need an alcohol stove or whatever he likes... my induction stove is not the cheapy units you see advertised on TV and is a chef/restaurant heavy duty quality unit and wired to the inverter with heavy 30 amp cabling... and inverter cables to the batteries are marine grade heavy duty cables. Not cheap for the faint of heart on a budget... the inverter alone was almost $800.
guitarguy56 is offline
