SailNet Community - View Single Post - Cetol Marine Finish Woes
post #22 of Old 03-31-2014
rbyham
rbyham's Avatar
Re: Cetol Marine Finish Woes
I too think wood prep is key. It is very easy to stop just short of the final sanding surface needed. Any "soft" teak layer will create a less than perfect application of any varnish. My guage for having reached the right level of sanding is when a tack cloth run over the surface does not catch at all... My recommendation would be to work with a short section and take it to complete smooth 400 grit. If that works you have your answer...
rbyham is offline
The Following User Says Thank You to rbyham For This Useful Post:
tomhuntdmd (05-26-2014)
