SailNet Community - View Single Post - safe cooking
Thread: safe cooking
post #183 of Old 04-01-2014
Puddin'_Tain
Don't call me a "senior"!
Puddin'_Tain's Avatar
Re: safe cooking
Originally Posted by guitarguy56 View Post
George... let's look at it again... 1500 watt appliance running 1 hour will be 1.5 kwatts per hour... a 1500 watt appliance running on 110 volts is using 13.6 amps per hour...
NO. One hour at a current of 1.5kW is 1.5kWh (1.5 kilowatt-hours)
...ask any electrical engineer, electrician, etc....
Be my guest
...the usage of watts drops as the appliance is reduced in time per minute.
Here is a simple calculator:
Calculate the Costs to Use Electricity - WebMath
Use that calculator. 1500 Watts for one hour equals 1.5kWh (kilowatt-hours, NOT kilowatts per hour)
...add the 1500 watts and the number of mintues... see if you don't get the same answers I shown you... you may have to convert kwatt hours to minutes to get the actual watt/minute usage.
Does it make a little more sense now?
Maybe in your universe. On Earth, a Watt is a joule/sec or a volt-amp. Check any, ANY, freshman physics book, or even Wikipedia.
"If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps a bit better than most." --- E.B. White
Puddin'_Tain is offline
