Backing Plates for C&C34 Stantions
AHOY!!....You can over plate and underplate, but remember that you''re augmenting an inital installation that was fualty; so you''ll have to go the extra mile to make sure you''re going to resolve ALL the issues and not just exacerbate an already poor state of affairs.Stanchion posts and mountings are notorious world wide for problems;...leaking being the most common, and of course the fibreglass issue,...well, you''re already working against a life expectancy that may have expired....cosequently, cover the bases any way you can. Take you upper and lower plates to a metal fabrication shop and have them apply the curve as supplied by you with a template;..then if you do use polysulphide, make CERTAIN that it''s TWO part rubber;....NOT that octopus snot that comes out of a tube..Meanwhile you may have to rebuild the entire area around each stanchion, in earnest....you may even go to carbon fibre if the areas are requiring compact re-inforcement.........Rev. Mike
