SailNet Community - View Single Post - Coolant Question
post #2 of Old 07-20-2007
Cruisingdad
Best Looking MALE Mod
Cruisingdad's Avatar
Hi Labatt,
I am not a diesel mechanic, so I will tell you what I do...
Regarding the overflow, assuming that is what you are talking about, yes, fill it up to the cold line. Your mixture should be 50:50 antifreeze and water. Also, with the engine cold, check the "radiator cap" and make sure she is full. I use automotive type antifreeze/coolant.
I would just add new coolant unless the old needed replacement. One word of warning that I have been exposed to: Often times when changing out the fluid, especially if flushing it clean, you will expose any pin holes. Watch for leaks if you do flush it. I am not sure why that happens, unless the flush cleans out the lines/rust that clogged the holes in teh first place.
One other question: Where did the fluid go?
Again, these are what I would do. If someone more knowledgeable knows better, please feel free to correct me.
- CD
Sailnet Moderator
My Website:
Follow My Blog at:
Follow me on Facebook:
Cruisingdad is offline
