SailNet Community - View Single Post - Maiden Voyage Newbie Trainwreck
post #73 of Old 04-03-2014
TakeFive
TakeFive's Avatar
Re: Maiden Voyage Newbie Trainwreck
Ulladh has suggested a very nice practice area. Lots of tacking space, as rivers go, and you can stay out of the channel and do careful crossings of the channel if you want to use the whole width of the river.
One critically important thing that may be so obvious that nobody has mentioned it: STAY WELL CLEAR OF THE UNDERWATER DIKE! It's well marked on the chart, and there are warning markers on the river, but do not try to cross it between the markers. Many lives have been lost to drunken powerboaters thanks to that dike. The ending marker for the dike is off Deemers Beach, where the huge boatel building is located. 1/2 mile north of there you'll see the moorings for the New Castle Sailing Club's fleet.
Also note that there is a shallow shoal between tower #2 and 3 (using Ulladh's numbering). You can squeeze through hugging the west side (near tower 2), but the best tacking space under the power lines is between #3 and 4. You need to decide early which way you will go, because the shoal will prevent you from changing your mind once you're committed. Make sure your route is lined up properly - I've found that optical illusions can be deceiving around that area.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
