SailNet Community - View Single Post - Fusing Batteries
post #12 of Old 04-04-2014
Maine Sail
Maine Sail's Avatar
Re: Fusing Batteries
Originally Posted by tatracy View Post
Thanks Maine Sail. On the ground side. In the USE Switch setup, do I run a common negative cable between the house and reserve batteries in addition to a negative run to the Engine ground?
Yes house>start>engine neg are all tied together. The only time this would get tricky is if you needed a shunt for the house ban for a battery monitor.
______
-Maine Sail / CS-36T
Maine Sail is offline
