SailNet Community - View Single Post - Impeller replacement Merc 5hp
post #6 of Old 04-06-2014
newhaul
islander bahama 24
newhaul's Avatar
Re: Impeller replacement Merc 5hp
The five HP merc its easier to change the impeller however a length of bailing wire into the pee hose would clear any minor blockages also the pee water is derived from the exhaust cooling water check the impeller first they should be inspected annually anyway (ounce of prevention and all ) also the water cooling feed line boot is in the lower unit on the little mercs.
Illegitimus Non Tatum Carborundum.
newhaul is offline
The Following User Says Thank You to newhaul For This Useful Post:
jballou (04-06-2014)
