SailNet Community - View Single Post - Bristol 32 head floor
post #2 of Old 04-07-2014
Delta-T
Delta-T's Avatar
Re: Bristol 32 head floor
Hi Jim, can you take the strainer off and take a close up picture/ I don't have a shower in my boat so that is not something I have done. On my boat many things were installed and the boat built around it. I do know home shower drains, and they can be removed and replaced from the top, inside the shower with a special tool. Tool is a cheap little piece of metal that comes with the new fitting. Here is a setup you might have. See the caulking nut can be removed, and pipe is held water tight with the gasket. http://www.vizimac.com/shower-drain-...re-template-3/
Good luck,
Eric
Eric
Delta-T
1968 Bristol 32 Keel/Crb Hull 26
Narragansett Bay RI USA
Delta-T is offline
