SailNet Community - View Single Post - PSC 34 compression post
post #6 of Old 04-07-2014
Alannc44
Alannc44's Avatar
Re: PSC 34 compression post
I too had some water seepage. Turns out the mast was filling up with rain water. We drilled a couple of small weep holes in the base and the problem was solved. Before, when the water would rise up enough, it would spill into the PVC tube where the wires run through the mast base.
Alannc44 is offline
