SailNet Community - View Single Post - Diesel Heater/Home Heating Oil
post #7 of Old 07-30-2007
TrueBlue
Seņor Member
TrueBlue's Avatar
My diesel heater direct experiences have been with the old Espar 3DL heater, which my boat was originally commissioned with, and the Espar Airtronic 4D upgrade I installed last year.
The system I have is actually simple, consisting of a diesel fired furnace unit ignited by an electrical glow-plug. Diesel is delivered to the unit via a low amperage, in-line metered pump. Integrated circuitry regulates the required amount of fuel to whatever temperature the bulkhead mounted digital thermostat calls for.
A stainless exhaust conduit connects the combustion chamber to a stainless port, located on the exterior high side of the hull. Just below the aft cabin's rubrail on my boat - since it's 5'-10" above the water line. Most other sailboats have the exhaust located on the transom.
Fresh air is provided by an above deck intake vent. There are six individual, damper controlled forced air outlets, positioned throughout the boat, all connected to the furnace plenum by concealed, flexible round ducts.
The Espar 4D sips fuel with the meter pump and only uses .8 to 3.0 peak amps during use, 12 volts - so heating the boat away from shore power is of no big concern. More info on Espar is available HERE if you're interested.
True Blue . . .
sold the Nauticat
TrueBlue is offline
