SailNet Community - View Single Post - Securing the Rode
post #2 of Old 08-02-2007
sailingdog
The end of the rode should be tied to a hardpoint on the boat. If you have an all-chain rode, you should use a long enough piece of rope to connect it to the boat that you can cut the rope without having to reach into the chain locker... reaching into a chain locker with a chain rode under tension is a good way to lose fingers.
I would recommend using a towboat hitch. These can be tied with out a bitter end and are fairly easy to release, even under a heavy load. With a chain rode, you might look at investing in a chain stopper as an option.
sailingdog is offline
