Not sure how much space you have on that port aft bulkhead - behind the nav station I think. But if you turned it on it's side could you make a bracket on that bulkhead that could hold the door ? or is it called a drop board ? and then it would just slide into the bracket with a little latch to secure it when on port tack ?
if it would be too tight you wouldn't be able to fit - although you could just make Fred do all the plotting
just my $.0125 cents worth
Who cares what psychiatrists write on walls !
