SailNet Community - View Single Post - H31 Prop Strut Hull Cracks
post #1 of Old 04-22-2014 Thread Starter
I've got what looks like stress cracks in the hull around the base of the prop strut. From the inside of the hull things are dry. There are some very slight cracks around some of the periphery of the mount, but the strut itself is not loose and doesn't have any play in it. Cutlass bearing is good, no significant play.
Inside view:
Side view, outside:
Rear view, outside:
No binding on the prop shaft, which leads me to believe there's no significant misalignment.
1) Cause(s)?
2) Solution(s)?
From the outside it certainly looks like it's seen some "bodywork" before. I'm figuring that I need to dig out all around that crack, clean it out, check it out and then refill it with...?
Suggestions welcome and needed!
Canadaler is offline
