SailNet Community - View Single Post - your favorite small cruising (blue water) boat
post #5 of Old 08-08-2007
sailingdog
Southern Crosses are pretty solid boats. Unless they damaged the hull or added a through-hulll improperly, they don't seem to have many hull core-related issues. IIRC, many had owner finished interiors, so the layout and quality of the interiors can vary quite a bit.
One thing I've seen that leads to problems on boats with cored-hulls is when someone attaches something to the interior surface, but doesn't pot the hole with thickened epoxy. If the attachment is down in the bilge, water can often get into the cored hull laminate via the screw hole. On one boat, don't believe it was an SC, there was a lot of "moisture" in the hull, and it turned out to be from a screw that was used to hold a bonding wire support in the bilge.
sailingdog is offline
