Old 08-09-2007
Sapperwhite's Avatar
Sapperwhite Sapperwhite is offline
Not So Senior Member
Sapperwhite has a spectacular aura aboutSapperwhite has a spectacular aura aboutSapperwhite has a spectacular aura about
Originally Posted by richnren View Post
Also, the extra pump makes bleeding the engine a whole lot easier.
All I do is open one bleed screw, turn on the "Ignition" switch, and hold a paper towel to catch the fuel. When the pump pushes fuel into the paper towel, I'm done.
I could imagine. The POs had bypassed the aux pump, probably becasue it had died and they didn't want to replace it, and fitted an in line priming bulb in its place for bleeding the engine. I've found that the priming bulb works well when I do any engine work that requires bleeding.
Still going to have to replace the pump though, I just might leave the bulb in line as second defense.
