SailNet Community - View Single Post - Teak Handrail Repair
post #9 of Old 08-13-2007
sailingdog
I don't recommend the threaded inserts... since then you're depending on the strength of the adhesive used to hold the railing in place. The loads that can be placed on a handrail, as HS has pointed out, can be fairly high, and it is much better to not depend on adhesive holding the inserts in place, since a through bolted handrail will be much safer and secure IMHO.
sailingdog is offline
